If you can't turn HTC One on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One.
Resetting HTCOne Hard reset
Http://www.htc.com/us/support/htc-one-m8/howto/465049.html
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is...
hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S.
Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure.
Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
2. Press and hold Volume Down and Power.
3. Keep holding both buttons until you see the Android logos appear on the screen.
4. Use the Volume Down button to toggle the selection and highlight Factory Reset.
5. Use the Power button to choose Factory Reset.
The HTC Inspire 4G will then complete the hard reset process. SD card data like music and photos should be preserved.
Software method
If you can boot into the device, you can use this option.
1. Tap the application slider and select the Settings app.
2. Select SD & phone storage.
3. Choose Factory data reset.
4. Select Reset phone.
5. Select Erase everything.
