It is normal to have about a 1/4" worth of water in the bottom of the tray, it's good to have a small amount of water in the dispenser to help dilute the fabric softener a bit to allow it too pass threw the hoses better. If the cup is completely full of water then there is probably softener clogging ports and just needs to be cleared.
Make sure the tray is clear and not blocked in any way. To check this I normally get a kettle and fill the tray with water this will then drain away easily providing its not blocked. Good luck.
This is normal to have left over standing water in the softener dispenser cup. That being said, some units can have more standing water than others because the machine isn't level (try leveling the unit).
Note: Softener is a "wax" and can clog up the water inlet openings. You can remove the whole dispenser assembly by pulling all the way out and depressing a button while pulling on dispenser tray. (button located middle-back)
For future parts or diagrams visit us here. Appliance Parts
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
