My Maytag dishwasher Quiet model is making a terrible noise about 1/2 way through the wash had a friends husband whos a repair man charge $60. to clean it out and say it might be off balance and to ta
Machine is about 5-6 years old. odd noise could be in a rinse / empty mode it is not off balance and cleans the dishes fine. ran a full hot empty cycle to clean it but still make s the weird noise...
is the nois a grinding, whirring noise? I think the motor coupling has gone bad. Not an extremely hard repair and a repair man should only charge around $25.00 for the part and his service call. You can do this yourself if your mechanically inclined. the coupling is under the drum and you have to take the front cover off to get to it.
Sounds like an internal timer malfunction.
Maytag Customer Service: 1 (800) 344-1274 U.S. Try to find your model # and serial number if not out of warranty before called. It sounds as if your machine needs to be inspected by a service repair agent in your area. Maytag can lead you to an authorized local repair man.
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
sounds like the macerator is bent out of shape from something going through the pump. Get a impeller kit and replace all the parts and you should lose the grinding noise. I can look up the part number if you want
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
I hope this helps you. If you need further assistance, please post back and let me know.
PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
