What you want is to add an iPad to your network. If you mean logging in on your Wifi at home, that is easy, but you probably mean you have lost the password of the router.
Reset the router to factory default: pull the plug and leave it unplugged for at least 10 minutes.
Check on the backside if it has a sticker with the default passphrase. After starting it up try this passphrase on the iPad.
If it has no sticker: Try Google: type in your brand and model of router with added "default wpa password". This might give a default password for your router on some site.
Do learn to adjust the password on your router: mostly you can type the IP address of the router in your browsers address bar
Try 192.168.0.1 or 192.168.1.0 (might be mentioned on the sticker also) then you get a weblogin page for the router.
Mostly you will need as user 'admin' and a password on the sticker.
Search for WPA2 passphrase in the setup and set that notch and adjust to your own password.
Use this password on the iPad:
goto settings - wifi and choose your network, give in your own password.
which Password are you talking about? The locked tablet Password or the password to your account? If you are talking about the locked password for your tablet you have to go into settings and then to privacy and then change password.
Hello If you did forget the password, there is no other way than contacting the nearest authorised Service center for Pioneer at your town. No adjustments cannot be done with this set, except deleting the present password. But to delete the present password, you must have the original password you did set at first. OK.
Solution : Perform an Automatic Gradation Adjustment (Color Calibration)
Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
Copy Density = Normal or Auto
Color Shift =Normal
Saturation = Normal
Color Balance = 0
Sharpness = 0
Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
Select [System Settings]. The System Settings screen will be displayed.
Select [System Settings] again.
Select [Common Settings].
Select [Image Quality]. The Image Quality Adjustment screen displays.
Select [Automatic Gradation Adjustment].
Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
Select the desired gradation adjustment screen.
Press [Start]. The Adjustment Chart is output.
NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
Press [Start].
To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
Color Shift =Normal
Saturation = Normal
Color Balance = 0
Sharpness = 0
Press [Start].
HI,
the BV9560B use 2 passwords.
one for the bluetooth and children restrictions "0000"
and the master setup, for touch and others "8888"
but be careful with the touch adjust... i have serius problems with this settings
see you
You may have to reset the password which will reset to the router to Default Settings. Do this by using a paper clip to push in the little button in the hole, in the back of the router. You will need to re-adjust your settings if you had Encryption or anything and I would suggest settings a secure password. If you do not like this solution you must guess the password.
I am not 100 percent what you are asking but I will answer the best I can with your question.
Press the [Administration] button located above the numeric keypad
on the Control Panel. The Administration button has a wrench symbol
located above it. The Access screen will be displayed.
Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
Enter your numeric password using the keypad.
If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
Select [Enter] on the Touch Screen. The Tools screen will be displayed.
Select [System Image Quality]. The System Image Quality screen will be displayed.
Select [Image Recognition]. The Image Recognition screen will be displayed.
Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
Select [Change Settings]. The Screening Adjustment screen will be displayed.
Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
Select [Close]. The System Image Quality screen will be displayed.
Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
Select [Halftone Screen]. The Halftone Screen will be displayed.
Select either [Halftone 200 line screen] or [Photograph 200 dpi].
NOTE:
Do not select 'Printer use' as this will effect print calibration;
which will be handled directly by the color server set up to print to
the copier / printer.
Select [Save]. The Auto Screening Adjust screen will be displayed.
Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
Select [Print Test Original] to print a sample of the settings. The
message 'Please wait…Printing test original' will be displayed and the
test original will print.
NOTE: If selecting
[Print Test Original] displays the message ‘System Disabled' then
Screening Adjustment is disabled. Select [Close] and repeat steps 5 to
16.
Open the Document Glass Cover.
Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
Place 5 sheets of blank white paper directly on top of the test original.
Close the Document Glass Cover.
Select [Start Adjustment] from the Touch Screen. The message
'Please wait….Adjustment in progress' will be displayed, then the Auto
Select [Adjustment Complete]. The message 'Please wait…Printing
current settings' will be displayed and the adjusted original will be
printed.
Examine the adjusted original to make sure the image quality is
satisfactory and continue to the next step. If the image quality is not
satisfactory repeat steps 12 through 22.
Select [Close]. The Tools screen will be displayed.
Select [Close]. The default copy screen will be displayed
