The solution is a factory reset....I know you have done this but did you follow this procedure?
1.Make sure the tablet is off and not in standby.
2.Hold down the 'Volume Up' and 'Power' buttons simultaneously until the two Android icons appear.
3.Use the volume buttons to select the white box on the right.
4.Once selected, press the power button.
5.Use the volume buttons to select 'wipe cache partition' and then press the power button.
6.Select 'Yes' and press the power button.
7.Use the volume buttons to select 'wipe data/factory reset' and then press the power button.
8.Select 'Yes' and press the power button.
9.The tablet will now reset.
1. Make sure that your wi-fi settings are turned on.
2. Scan for local wi-fi
3. Select your desired wi-fi and provide password if required.
Many times, the settings from the menu are not turned on, so the tablet will not try to link to a wi-fi site.
If you need more help, please provide the model number and the operating system currently being used on the tablet.
toshiba excite 16gb 10inch i went to settings to turn my wifi on nd it wont let me it doesnt let me add a network or scan it just say turning on wi-fi is been 2days now please help i even reset my tablet couple of times and nothing
SOURCE: my wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
SOURCE: the combination fn+f8(the wi fi button ) is not working
nothing you can do about it ... if you dont use the wireless you can disable-it from bios and the light willl shut down....
i have the same laptop ..and except the battery that goes fast it's a reliable laptop
PS you would better use w7-x86/32 bit and it will performe better
SOURCE: kindle is jammed on wi
Firstly, make sure that your kindle is fully charged. Then hold the power switch for 7 seconds. After the light blinks three times, release it. If this does not unfreeze your kindle, hold the power switch for 15 seconds. This should restart your kindle. If neither of these solutions work try contacting amazon kindle support, as they can remotely connec tto your kindle and see what is wrong.
Cheers
Sine Wave
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
