Dishwasher has worked great since last year when I replaced the entire circuit board. Recently the unresetable bi-metal heat sensor popped out so I replaced it, but the new one did the same thing after only a cycle or two. I was able to reset the switch by drilling a small hole in the back and inserting a paper clip to pop the strip back the other way again, but it only worked for two cycles and then popped out again.
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
SOURCE: Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
SOURCE: snap on fitting no longer stays on faucett
go to www.searspartsdirect.com and you can search by your model number for the dishwasher or any other kenmore part. The schematics magnify as you mouse over them and then you can scroll down to see the matching part number. The part 3378117 is the whole hose assembly including the faucet coupler and the full length of the hoses. Notice that the part number 3378117 has been substituted with W10217197. When I Googled for "W10217197 dishwasher" there were a number of vendors selling that part including ApplianceZone.com selling it for $20 less than Sears and other vendors. Unfortunately the way the faucet coupler is crimped onto the hoses you have to replace the full length of hose [not just the coupler] but I have a problem that requires the whole hose. I've opened the cabinet up - which required a star headed driver - and from there it's just a matter of removing basic connectors inside the box.
Daniel
When the original unresetable bi-metal heat sensor popped I replaced it. That worked for a cycle or two, but then the new one popped out. What would cause it to do that? did I just get a bad replacement, or is something else overheating and causing it to pop?
