Will not power on at all.
Remove the top cover, screws are under the metal trim band with the writing on it. Get a multi meter and follow the power. Where the power stops is a good place to start looking. I think the electric internals consist of a PCB complete and a motor complete. If the motor has a circuit and both field windings are even resistance then you are probably looking at a pcb replacement unless you are an electronics whizz. There may also be an interference suppressor across the mains power supply in some countries, unlikely that will stop it though. Certainly look for any unplugged or broken connections inside from mains cable to pcb.
