SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
SOURCE: rangemaster 110 main oven does not work
That looks like a problem with the control panel assembly.
Try first unplugging power cord for ten minutes, then plug back.
Press the selector wheel for 5 seconds and see if this reset it.
If that does not work , then you need to replace the control assembly. YYou find diagrams and replacement parts by entering the model number here.
Hope this helps with your dual fuel version 3 weeks on and working perfectly!
Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
SOURCE: their was apower cut now the clock and fan oven
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
SOURCE: how do i bypass the clock on my rangemaster 110
Have had trouble with our timer on our Rangemaster 110 so ordered a new timer only to be credited as it is no longer available. Dont realy want to buy a new cooker this side of christmas, any way of bypasing the timer ?
