SanDisk Sansa e260 MP3 Player Logo
sTAN kAWECKI Posted on Feb 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Sansa E260 does not see the inserted SD card
Inserted the SD card, and it is not recognized. Cleaned contacts on the card
The Dude
Level 3:
Master:
  • Master 147 Answers
  • Posted on Feb 03, 2015
The Dude
Master
Level 3:
Master:
Answers
147
Questions
17
Helped
21064
Points
5959
Reboot the system and try again. You have to make sure it's shut down when you're inserting the card. If it still doesn't work make sure it has updated firmware. Sometimes that can cause some issue as well.
1helpful
Is it possible to play the songs stored in the SD card when inserted in Sansa e260
Yes. However, all your music must be in a folder called "MUSIC".
BTW it's a microSD card, not an SD card.
5helpful
2answers
4helpful
Micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
2answers
Micro sd card
Does your computer has an internal card reader?
1helpful
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
61helpful
9answers
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
2helpful
4answers
Cannot get my computer to recognize my sansa e260 player
I cannot get my desktop to find a driver for the e260, but if you use the SD microdisk you can load stuff to the microdisk if you have a card reader. You need to buy the full size SD card with the micro SD attached. Then sync the stuff you want to load and when you boot up your player, it will refresh the data base and you can play the stuff on your card. Seems a shame to waste 4 gigs of hard drive on the player, but I do not know anyone who has found a driver for the e260 that works with XP service pack 2. If you do please send me an email me.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
