Interlock switchIf your
microwave is turning itself on, the first thing to check is the
interlock switch. This is usually the first thing to malfunction that
could cause this issue. If the interlock switch is bad then it will need
to be replaced.
Main control boardIf
your microwave is turning itself on and the interlock switch is still
working, the probable cause is the main control board. If the control
board is defective it will need to be replaced.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a NEW question, and please
include your brand name and the full model number from the tag in or on
the unit, as well as the answers to these questions:
Which fan is it?
The internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Q - My microwave seems to shut off every once in a while, what might be wrong? A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt. Q - The fan in my microwave oven is not running will this hurt my microwave? A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace. Q - My microwave blows the fuse inside itself as soon as I push the start button. A - Usually a shorted high voltage capacitor...see components section.
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
If
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
