I plug it in and it wont charge. I use the plug in charger that came with the tablet and it just wont charge. I plugged it in 2 hours ago and just checked and it says 0% charged. When I plugged it in then it was 4% charged. My son gave me the tablet for Christmas so it isn't that old. model number is MST9-21
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
SOURCE: my tablet wont charge or turn on please help
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
