Microwave Ovens Logo
M
Mike Whalen Posted on Feb 03, 2015
KitchenAid mircowave door torsion spring replacement mod KBHC109JSS03
How do I replace the springs and where exactly are they
5 Related Answers
Anonymous
  • 1010 Answers
  • Posted on Jul 06, 2008
SOURCE: how to change leaf springs on my own?
Go to 4wheelparts.com
Find a store near you and plan on spending some hard earned money. They will help you to pick the BEST solution for your needs... springs, shocks,bushings and so on...
you can install new suspension if you have the right tools... but it is probably easier to have it done...No headaches
also... air springs?.. you may need some extensive fab work..I would definately go to 4 wheel parts to find what you need
Anonymous
  • 1861 Answers
  • Posted on Nov 21, 2008
SOURCE: Broken spring on the gas fuel tank door on Toyota ''Camry'' 1998
Go to your nearest Toyota dealer. Purchase this part number: 77360-22020; approx 4 dollars.
Open the fuel door. Being careful, remove the leftover plastic that is hooked by the door hinge. Insert the new spring assembly under the slot, and press it in until it clicks into place. Very easy to do.
Hope this helps, and thanks for choosing FixYa.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 25, 2008
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • Posted on Mar 26, 2009
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Anonymous
  • 1586 Answers
  • Posted on May 01, 2009
SOURCE: Replace coil spring
You have to remove them - that "block" is the upper strut-to-body mounting section and serves as the upper seat for the spring as well as the anchor for the top of the strut. You need to take those four 17mm bolts out, as well as the rear upper sway bar bolt, the upper control arm bolt (at the top of the hub), and the bottom bolt on the strut, where it goes through the lower control arm. You'll then have to compress the spring enough to take the bolt out of the "block" (it goes through sideways, and I believe is 19mm on the bolt head as well as the nut). At this point, you can slide the spring/strut out of the block, decompress the spring, pull out the strut, and install a new spring over the strut. Recompress enough to get the top of the strut visible through the anchor bolt hole in the block, rebolt it, decompress the spring, and reinstall the assembly in the car. Usually when you go to reinstall it, the bottom of the strut is not angled quite right once the top four 17mm bolts are back in and the block is secured to the body. I put a large screwdriver through the lower strut bolt hole at the bottom of the strut and use that to turn it, or I grab the weld near the bottom of the strut with large ChanneLock pliers and turn it until it's aligned with the control arm properly. Once it is, put the lower bolt back in, rebolt the control arm and sway bar, and you're good to go.
Note - this job will not affect alignment specs - you don't remove any bolts used in aligning the car, so that's not a concern when doing this repair.
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Door spring on microwave
KA MW use torsion springs 2 about 50 a piece
How to replace torsion spring in the microwave door
If this is the flip down door. You will need to take apart the side cover of the unit to fasten the spring. Once you have done that you need to put a pen or something to hook it so it doesn't drop down in the unit. If you are unable to hook the spring in the door. You must take the outer cover off the door to hook the spring and then replace the cover. You may find this to be a two person job and may be easier to hook the door before you hook the unit. Some doors are different then others.
6helpful
5helpful
3answers
Light and door spring
I had a tension rod break in my door as well. There are two of them that cross forming an X and you can see them when you open the door and look in the crack. Fixing them is very easy once you get the outer panel w/ glass and the black molded plastic piece off. WARNING, when you open the door there are two screw on the inside top part of the door assembly. THEY ARE THE ONLY TWO SCREWS HOLDING THE ENTIRE FRONT PANEL/GLASS ASSEMBLY IN PLACE. I found this out the hard way. When the 2nd screw disengaged the whole assembly came crashing down shattering the glass and nearly cut off my toe. Be very careful when taking off the outside panel!!!
Next challenge...the black molded piece that also needs to come off. To remove this take off the piece that surrounds the exhaust tube to get at two screws that are directly underneath the molded plastic piece. After getting that off you have access to the two rod and can get them installed without to much trouble.
Again, be very careful when removing the front panel. My repair went from an 18 dollar tension rod to a $200 dollar front panel and nearly cost me a toe (yes, I was barefoot).
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
