Red is Common hot Blue is power antenna Yellow is stand By Black is ground Radio and Car should Be SaMe ColorsBlue is not Nessicary uunless You hare Power antenna Yellow keeps Time and Channel memory Red Black is a must
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the
steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug) Rear Right speaker -: Blue w/White stripe Rear Left speaker -: Brown w/Yellow stripe Front Right +: Purple Front Left +: Dark Green Rear Right speaker +: Blue w/Orange Stripe Rear Left speaker +: Brown w/Blue Stripe Power Antenna/Amp: White (Gray Plug) +12v battery wire: Pink or Pink w/White Stripe +12v Ignition wire: Red w/ White Stripe Front Right speaker -: Blue w/ Red Stripe Front Left speaker -: Brown w/ Red Stripe
use at your own risk. I can not confirm these.
+12V DC Battery(Constant)
Yellow/green
31
15 Amp
Fuse box on left front of engine compartment, near battery.
Switched Accessory
Purple
6
10 Amp
Fuse block behind left side of dash
Power Antenna
NCA
Green for antenna signal
Illumination
Red/yellow & red/blue
Steering Wheel Control Wire
Red/white, green, and blue
If equipped, as for Mid-Line.
Left Front +
Blue/white
Left Front -
Blue/red
Right Front +
White/black
Right Front -
Blue/black
Left Rear +
Green/yellow
Left Rear -
Black/yellow
Right Rear +
Blue
Right Rear -
Red
AT SPEAKERS
Wire Function
Color
Note
Left Front Tweeter +
Blue/white
Left Front Tweeter -
Blue/red
Right Front Tweeter +
White/black
Right Front Tweeter -
Blue/black
yellow battery red accessory black ground purple right rear + speaker purple/black right rear - green left rear + green/black left rear - white fr left + white/black fr left - grey fr right + grey/black fr right - blue auto antenna blue/white rem amp brown phone mute orange/white illumination grass green handbrake but if u want to play dvd's whilst u drive connect this to earth
thats the radio here's the diagram for your car 1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
