Hi Greg!
Yes, it's possible.
We produce an external box (very small dimensions) to connect BT device (such as tablet Win10 or WinMobile controller) using the serial port (Lemo plug) of your TCRA.
If You need some infos, pls contact me via email [email protected]
Bye!
Carlo Alberto
If a wrong PIN has been entered five times, the system will prompt for a PersonalUnblocKing code. The PUK code can be found on the instrument delivery papers.If the PUK code entered is correct then the instrument will start up and reset the PIN code to default value 0 and Use PIN Code : Off .... reallly I have the same problem but I lost its delivery papers
Rr
