Hi Alma Lasater, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi Alma Lasater, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Generally, on most modern tv's the answer is yes. if you're connecting via an A/V amplifier then no problem at all but you stated that you're after a direct to tv connection.
But the answer depends entirely on the make and model of tv and whether it has standard left and right phono inputs. If it only has Scart sockets (UK/Europe only) then there are adapters which will do the job.
As you haven't given any details at all about your tv I cannot give you any more specific details.
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
The CD/DVD player has three output ports: (i) Line out Video used to connect the yellow pin of composite cable. (ii) S-video out use d to connect an S-video cable. (iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV. In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
