Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
I've allready changed the door lock but still got the same error
