Attempting to remove control panel to access door opener
SOURCE: Replace microwave door
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 On exploded view diagram 4, look at reference part number 4. That is the choke cover. It's held in place with hidden tabs. I've attached a diagram from a Sharp model that will be somewhat similar. Once the choke cover's off, the hardware should be visible. The diagrams do not show the hinged at all. That may mean they're welded to the chassis of the oven. Write back if this does not clear it up.
SOURCE: door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
SOURCE: DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
SOURCE: Kitchenaid microwave (builtin) door jammed
I believe the only way of gaining access to the door latch assembly is by removing the cover. You can use needle nose pliers to grip the sides of the screws to slowly turn them out. You might want to visit this web site www.applianceaid.com enter your model number then scroll down until you see an exploded view of your model. Click to enlarge the diagram of your model exposing the latch assembly. I hope this is of help to you. If you found any of these suggestions helpful, please rate my solution. D. Lange
SOURCE: How do i replace the door handle
with most microwave ovens, for safety reasons... they are permanently sealed to prevent microwave leakage burns... i hope this helped you out..
