Hand Tools Logo
b
betty joann tessinear Posted on Feb 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I live in Forest City area-close to Spartanburg, SC-where can i go to get small Black n Decker battery operated tools fixed
Looked for model/serial numbers-could not find
Robert Kulkofsky
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Jan 09, 2018
Robert Kulkofsky
Expert
Level 2:
Sergeant:
Answers
200
Questions
5
Helped
47331
Points
595
Generally the repair is more costly then just getting a new one, especially black and decker
5 Related Answers
A
Anonymous
  • Posted on May 31, 2008
SOURCE: Black and Decker Blender Model Number 675 Replacement Parts - Collar
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=5&CategoryID=1&gclid=CICJ0pWm0ZMCFQnIsgodnkhAhg
Anonymous
  • Posted on Nov 20, 2008
SOURCE: Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Anonymous
  • 4234 Answers
  • Posted on Jan 06, 2009
SOURCE: registering 2 black and decker tools.
Changes were made to the website. Start at blackanddecker.com and select the customer support option that appears at the top right of the page. You will see the option to register your products on the left under heading of products and services. Click on product registration. Sign in as a guest and you should be able to register your products.
Hope this helps,
Dan
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on May 27, 2009
SOURCE: Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
Enjoy!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
VtToolMan
Mark
  • 704 Answers
  • Posted on Sep 12, 2009
SOURCE: black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
I need a Replacement battery for a Black & Decker Scumbuster S600? Where can I find one?
$19.95 below
Black and Decker S600 Type 1 Scumbuster Parts
Replacement Parts https://www.ereplacementparts.com > black-and-decke...
Fix your S600 Scumbuster Type 1 today! We offer OEM parts, detailed model diagrams, symptom-based repair help, and video tutorials to make repairs easy.
Black & Decker Type 1 Scumbuster Power Tool Batteries
Battery Mart https://www.batterymart.com > c-black-decker-decker-...
Replacement Black & Decker Power Tool Battery (3.6V, 1.3Ah, NiCd) ; Voltage: 3.6 Volt / 1300 mAh ; Dimensions: 1 dia. / 4.5 height ; Weight: 0.83 lbs ; Warranty: 6 ...
US$19.95
Black and Decker small grinder power cable
notify tool repair shop in your area --black and decker support or online search
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Before the invention of the hammer drill, people face a lot of trouble drilling in the tight spaces. They had to break down the parts in smaller units in order to drill it properly. But, now the time has changed and the users can easily drill on a portable manner. But, one might wonder, what makes the best hammer drill
? The answer is being more and more complicated each year with so many brands on the market.
The market offering is huge and most of the brands are continuously reinventing their products. We have analyzed many different drills from cordless hammer drill to a corded hammer drill, to hammer drill machine to cordless hammer drill drivers. Thus, we have come up with these top picks.
How to fix a 24 volt black and decker battery charger
You need to post MORE information like what is it doing or not doing and how you use this charger then we can eliminate operator trouble and focus on the charger.
Transformer
look at your charger,on sticker you have the power it drain.
Where is the serial number on my black and decker table saw
You would be looking for the Model number, not the Serial number. I don't know if that will help you find the right manual. But here's something else -- a table saw is an essential woodworking tool, but without some basic instruction can be VERY dangerous. There are many sources of information about how to safely use a table saw that would all serve your son even better than having the specific user manual. There really is not all that much difference between the basic operation of any of the consumer marketed table-saws anyway.
Need operating manual
Hello, To get your manual go to Black & Decker.com scroll down to manuals click add model number and product or call 1-800-554-6986,down load and print manual,hope this helps, ``
I have a 7" angle
There are 3 versions of the 7" grinder model 4074. Sears Parts Direct has the manual for sale http://www.searspartsdirect.com/partsdirect/part-number/BLACK-DECKER-Parts/Grinder-Parts/741333-00/0009/900/Model-4074/1228/0721050?keySuffixId=NA&productTypeId=x&searchModelNumber=4074&subCompDesc=Unit%20parts&brandDesc=BLACK&DECKER&modelDesc=7 .
Black and Decker has pdf versions of the manuals for many of their products are here: http://www.blackanddecker.com/manuals.aspx . However, check the model number on the grinder. 4074 doesn't come up as a valid model. The usual model numbers start with alphabetic characters to indicate the type of tool. The site lists where to look for model numbers.
I hope this helps.
5helpful
2answers
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Top Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you a Hand Tool Expert? Answer questions, earn points and help others
