Cars & Trucks Logo
j
joshya pleake Posted on Feb 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I hook the wires to a stock radio in a 1996 ford ranger 5 speed
Looked up wire diagrams tried to hook back up
riggsa1cad
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 111 Answers
  • Posted on Feb 02, 2015
riggsa1cad
Expert
Level 2:
New Friend:
Cheetah:
Answers
111
Questions
Helped
51504
Points
276
Get a vehicle radio adapter harness
My radio want come on 94 ranger truck all fuses looks good
Your power Wire from your Battery to your radio may be cut or pinched. Also your remote turn on for your Radio could be messed up. If its stock then refer to the vehicles user manual for wire color. If its Not stock refer to the serial number on top of the radio for a diagram for wire colors for designation and check them and their connections if all of those are good then its more than likely your radio
1helpful
2answers
I need wiring diagram for my truck
Try WWW.Crutchfield.com they have all the connectors you need to connect aftermarket units to the factory wiring.
Dashboard lights will not turn off
Pull it back out, (Radio) and recheck your steps. Something is not hooked up right. When you pull it back out, See if it goes back working normal. Retrack the wires. You cut are hook up something wrong????
No spark at all!
you need to check the fuses again under the hood and under the dash if all are good look for a bad fuse link if you melted wires you had to blow fuses or fuse link
2helpful
2answers
Need wiring diagram for 1997 ranger stereo
1997 Ford Ranger Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Purple
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
