Krups Dolce Gusto KP 2100 Espresso Machine Logo
s
sandra scott Posted on Feb 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi ive tried everything but the draw still wont open on my dolce gusto can you help please
Everything but still wont open
graybeard32301
Level 3:
  • Master 382 Answers
  • Posted on Feb 01, 2015
graybeard32301
Master
Level 3:
Answers
382
Questions
0
Helped
128257
Points
1328
If something is broken inside, it will need to be taken apart for repair. Before that, try the following:
  1. Unplug it.
  2. Move the selection lever from cold to hot and back several times. Be sure the lever will move full stroke smoothly. Put the selection lever in the center position.
  3. While firmly pulling the draw outward, "snap" the draw upward.
If that does not work, it will need to be disassembled.
1helpful
Dolce gusto light turns yellow more orange. What is going on?
To solve you oregne light problem you must do this press power bottom for few seconds to make it flashing Orange this means that the machine is now in descaleing mode then do the descaleing product be sure you use dolce gusto descaleing only after you done reset power bottom this should solve the problem.that was a working for descaleing
2answers
I plugged my new dolce gusto picolo in for the first time yesterday to do the first clean through of water but no water is coming out
This is normal you have an air lock all most all new machens do that fill the water tank and only run water fro the cold side don't use the hot run water for 5seconds at a time it should the job
Why is my dolce gusto is leaking. can it be repaired?
remove the plate which is clipped neat the capsule holder and try again if it works see if you can opening the hole or replace
My Dolce and Gusto Piccolo isn't drawing water
Have you used the pin to clean the needle? It is located behind the water container. It may also then need a coffee machine cleaner to be run through it. Don't use cleaners for dishwashers or washing machines, as these don't look after the internal seals so we'll.
1helpful
2answers
Dolce gusto problem
In my case problem was dry/old electrolitic capacitor.
Label on PCB - C2
Value 470u/10V 105 degC
Spare parts for nescafe dolce gusto
m
hi ! my name is Tommy . I need the capsel holder for the dolce gusto delonghi
2helpful
3answers
Dolce gusto
Hi. I work at Nestle on the brand and it sounds like either a fuse issue or a clogged needle. Please call our consumer services number at 1-800-746-3391 for assistance. They are open Mon-Fri 8am to 8pm EST.
5helpful
2answers
I have a Nescafe Dolce Gusto coffee maker and when you press red switch it will not go to green
Hi Ron, my name is Katelyn, and I help with the marketing for Dolce Gusto. There is a live chat2_bing.gif with a specialist on our Web site (http://www.dolce-gusto.us/Public/Contact-Us.aspx) or feel free to call the consumer services at 800-745-3391.
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
