Red-red, white-white, yellow-yellow on the front and back of the dvd player
SOURCE: CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
HI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
SOURCE: DVD and the new converter box
Lorrie47, Need more info to help you. YRU trying to connect any A//V cables to the HDConverterbox to your DVD player? Can you plug the DVD player into the widescreen HDTVset or do you have old NTSC TV set like I do? I haven't even been to Circuit City, Sam's Club, or BestBuy to see what kinds of connectors are on those HD Tuner/Converter Boxes. Is the converter box u have equipted w/yellow(video), red(right), White(left) analog signal in's and out's? If the new HDTVconverter box has BASEBAND in's and out's then the installation/owners manual should have directions for their proper use. In any case you need to be more specific on what you are trying to accomplish. Tell me, does TV set stay on channel 3 , and never ever changed to chan22 or 51 or 8. Its always set to ch3?
Is it possible that maybe TV set has baseband (yellow,red,white) in's and out's on rear of cabinet? Now here are some rules to follow. Outputs must go to inputs. and colors must match. I assume that the HDTV tuner/converter box has a infrared remote control to do channel change and vol/up/dn and possiblly other things like switching of sources. does the manual say anything about AUX A/V inputs that can be used? Hpoe this has been of some use to U. I'm Louie12fix can be emailed @ this:
lmistyrel @ aol.com north of Chicago
SOURCE: what channel do I set my tv to to watgh a dvd
Mostlt likey 3 or 4.
Please explain how you have it connected so that I can be sure.
What input (connections on back of television) do you have it connected to on the television?
Or if you could explain the colors of your wires.
SOURCE: connecting tv, converter box, vcr, dvd player
You will need a splitter,
#bubwrapper {
position:relative;
width:98px;
height:113px;
#bubLyr1{
position:absolute;
visibility:visible;
width:0px;
height:0px;
left:0;
top:0;
padding:0px;
#bubLyr2{
position:absolute;
visibility:visible;
width:120px;
height:0px;
left:35;
top:-20;
padding:0px;
#bubLyr3{
position:absolute;
visibility:visible;
width:120px;
height:0px;
left:-61;
top:-32;
padding:0px;
#bubLyr4{
position:absolute;
visibility:visible;
width:120px;
height:0px;
left:200;
top:-20;
padding:0px;
#bubLyr5{
position:absolute;
visibility:visible;
width:120px;
height:0px;
left:-30;
top:-32;
padding:0px;
function showCustomPopUp(thisUrl,thisName,theseParams)
remote = open(thisUrl, thisName, theseParams);
function showEnhanced()
remote = open("/largeImage/index.jsp?LargeImageURL=" + escape(document.path.enh.value), "largeImage", "width=505,height=525,left=0,top=0");
function verifyFields(submitProcess,formObject)
if (submitProcess == "wishlist")
formObject.wlName.value = "wlName";
formObject.submit();
else
formObject.wlName.value = "";
ajaxAddToCart(formObject);
function popUp(URL) {
day = new Date();
id = day.getTime();
eval("page" + id + " = window.open(URL, '" + id + "', 'toolbar=0,scrollbars=0,location=0,statusbar=0,menubar=0,resizable=0,width=300,height=50,left = 337,top = 284');");
function submitCompare(thisForm, thisFormField, prodLength) {
var prodsToCompArr = thisForm.gridProductIdsToCompare.value.split("_");
var prodList="";
for(var i = 0; i
#stsbubwrapper {
position:relative;
width:98px;
height:113px;
#stsbubLyr1{
position:absolute;
visibility:visible;
width:0px;
height:0px;
left:0;
top:0;
padding:0px;
function showMsg(cnt)
var x = cnt;
eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'visible' + "\"");
eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'block' + "\"");
function hideMsg(cnt)
var x = cnt;
eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'hidden' + "\"");
eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'none' + "\"");
$10.99
2-Way Hybrid Splitter
Model: 15-1234 | Catalog #: 15-1234
Use to divide a signal to feed two TVs or VCRs, or to combine signals for transmission on a single c...
Connect conv box and vcr on the two terminals and the single one to the tv.
Hope this is a Fix Ya!
