Since there is no display ICs in nokia 6101 the most possible problem is the Strip.(pata).Ao, first of all change the strip and try if the problem remains the same You need to contact nearest mobile repairing shop for further examination.In case if the UPP IC got sort there is no solution other than bying new set.Good luck.Thanks for visiting fixya
go to the following website. and enter your imei no there. you will get a master code to reset your security code. http://nfader.su/ thanks for contacting fixya!
To reset some of the menu settings to their original values, select Menu >
Settings > Restore factory sett.. Enter the security code. The data you have
entered or downloaded are not deleted, for example, the names and phone
numbers saved in Contacts.
Try reset your phone to its factory settings! Go SETTINGS..... RESET FACTORY SETTINGS......then 12345 for the sec code.
if nothing happens, then bring your phone to service shop then let them solve the fault. im think there is a need to replash the firmware.Is this advice/solution helpful to you? You can send me email at [email protected] for my further assistance. Kindly rate this up! Thank you very much..
Have your phone reflash its firmware by bringing it to a cellphone service shop. Is this solution/advice helpful to you? You can send me email at [email protected] for my further assistance. Kindly rate this up! Thank you.
