Water doesn't come out of clothes in final rinse
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
When the clothes are wet at the end of a cycle, check these:
Motor coupler
To
test the motor coupler, re-start the washer in its spin cycle. Let the
machine run for a minute, and then open the lid and notice whether the
tub is spinning:
Spin cycle
If
the washer doesn't reach its proper spin speed, the clothes may be too
wet at the end of a cycle. Check to be sure the load is properly
balanced and run a spin cycle again. If the clothes are still wet, you
may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),
or a worn motor pulley or tub bearing. Replace the applicable
component.
Alternatively, there could be clothes caught
between the inner and outer tubs. Read the "It spins but won't pump"
section of the "It won't drain" section. Also, there could be other
things that cause friction on the drive train. Seek the assistance of a
qualified appliance repair technician.
Siphoning
If
the water that pumps from the machine goes right back into the machine
after the spin cycle, it may be because your washer is siphoning the
water from a laundry tub with a slow drain, back into the washer. Try
to improve the draining of the laundry tub. (Is there something stuck
in the drain?) Also, be sure the drain hose doesn't reach more than
about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet
valves eventually fail. One problem that may develop with a water-inlet
valve is that it can no longer completely shut off when the electricity
is turned off to it. Then, the valve may leak and drip water into the
clothes tub--you may notice that your washer has water in it when you
haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
SOURCE: Leak during rinse and final spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
SOURCE: After final rinse and spin cycle clothes are still wet
I can't solve this but am having a similar problem. There is no water in the tub but the spin cycle does not get enough water out of the clothes and they're very wet. This causes the towels especially... to smell really bad. The tub is very loose. How can this be fixed.
SOURCE: After the final spin cycle, my clothes are still wet.
Check these out:
