A code is blinking on our spitfire and can not get to run, code says speed control lever fault is indication, solution is, make sure speed control lever is in rest position(done) still wont run, any i
New batteries, taking apart and checking connections,
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
Your version has a Dynamic Controls model controller and joystick. Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand) Turn the chair off, wait 5 seconds, turn the chair back. If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors. 3=Left motor fault 4=Right motor fault 5=Left brake fault (may not be engaged) 6=Right brake fault (may not be engaged) Any other fault code usually means the electronics or wiring is bad and not worth fixing.
2 things prior to running the cruise control self Test
1. Do you have operational brake lamps ?
2. Have you had the recall done ? recall 05S28. Description: Speed Control Deactivation Switch. 1L1Z-9F924-AA 14 supplements in the recall series
Self-Test Diagnostics
WARNING: This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note: There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
- 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
- 3 flashes - deactivator switch is open or circuit defective.
- 4 flashes - vehicle speed signal is out of range or circuit is defective
4. Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
5. Return the ignition switch to the OFF position and proceed to the Symptom Chart.
The D4 light is coming on to tell you that there is one or more fault codes set in your transmission control module. The only way to retrieve codes on the 1995 models is to read "Flash Codes" output by the D4 light. (See instructions below)
RETRIEVING FLASH CODES USING THE D4 LIGHT
If fault codes are present, the D4 light will "blink" when the ignition is turned to the RUN position and will remain on at all times when the engine is running.
To retrieve the flash codes, turn the ignition switch off.
Install a jumper wire between the service check connector terminals.
The service check connector is a gray, 2-pin connector located on the PCM/TCM cover under the passenger side of the instrument panel. (See picture below)
CAUTION: DO NOT use the 3-pin located next to the service check connector.
Installing the jumper will place the PCM/TCM in diagnostic test mode.
Turn the ignition to the RUN position. Codes will be output by blinking the D4 light.
Note the number of blinks from the D4 light. A short blink indicates a single digit flash code. A long blink equals 10 short blinks. For instance one short blink indicates code 1. One long blink and four short blinks indicates code 14. If there is more than one fault code, they will be output one at a time from the lowest numbered code to the highest numbered code. It is recommended that you read the code or codes several times to make sure that you are reading it correctly.
Once you have retrieved the fault code(s) re-post your question and include the information for what codes you have and someone can then help you locate the cause of the problem.
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Did you have the recall done ? recall 05S28. Description: Speed Control Deactivation Switch.
Try the self test for the Cruise Control :
With the key off depress and hold the cruise control off button while turning the ignition to the run position,don't start the truck, the cruise light will flash once to let you know it is in self test. Five additional flashes indicate a bad cruise control servo
Release the cruise off switch and within 5 seconds depress the other switches in sequence: 1. on 2. resume 3. coast 4. set/ accel The speed control light will flash as each switch is depressed.
If the last one does not flash it may then flash a code
After this the cruise will move the throttle to test the actuator and the cable. Make sure the throttle returns to idle and turn the key off. ----------------------
I believe this fault code indicates a left parking brake fault. Check all the connections from the motor/gear/brake assembly on BOTH motors (sometimes the controller gets confused). Follow the wires from the motor to the controller and reconnect them all. Make sure the free-wheel lever is in gear by taking out of gear, and placing back into gear firmly.
you may have an air mix motor problem or a mode control motor problem. there is a test you can do that may help: 1. turn the ignition switch on. 2. turn the fan switch off. 3. press the recirc control button to select recirc (recirc indicator light comes on.) 4. press and hold the recirc button to select fresh (recirc indicator goes off). Continue to hold the the button down until the recirc indicator comes on for two seconds and then goes off. If the system is okay, the recirc indicator will stay off. If there is a problem, the recirc indicator blinks a code to indicate a fault. 1 blink=air mix control motor/circuit fault. 2 blinks= mode control motor/circuit fault. 3 blinks= evaporator temp sensor circuit fault. In case of multiple problems, the recirc indicator will only blink the code with the least number. write back if this test shows a code and we'll go from there.
