Question about Honeywell RTH230B 5-2 Day Programmable Thermostat Large
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
See previous question. I left batteries out for about 30 minutes, but no change in being able to adjust temperature.
    Sergeant:
  • 200 Answers
Your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Posted on Feb 03, 2015
SOURCE:
I put in a new Living Air XL-15 fan but no go.
Make sure that the pin on the back cover penetrates deeply enough into the unit to activate the power. I too couldn\'t figure out why mine wouldn\'t start until I pressed hard on the bottom right corner of the back cover. When I did the unit started immediately because the pin wasn\'t fully inserted. To solve the problem I held the cover tight with a piece of duct tape and haven\'t had a problem since.
Dec 13, 2013 | Alpine Air XL-15 Air Purifier
Packard Bell BL 2141 Q660, Denver 10 Motherboard. I Cannot set DayDate in CMOS
check if your clock battery on motherboard is working properly
Mar 17, 2017 | Computers & Internet
ET200 won't shoot nails. The light works but it doesn't shoot. The chamber is clear of jammed nails HELP!
I had this problem too, and finally figured out what was wrong. If you have cleared a jam and have put the nail gun back together, then all you get is a 'thunk' when you try to drive a brad, you have put it back together wrong, as I did. Take the two screws out and pull out all four pieces -- three plates and one skinny 'T' shaped piece. Look inside the unit and you'll see a pointed piece, which is the hammer that drives the brad in. This next step is key: put the first plate back in (the one that is flat on both sides) making sure that it slides in UNDER the hammer. The hammer fits loosely in its housing, so it may help to turn the nailer upside down so that the hammer falls down, giving you the room you need to get the plate in--again, so that it's UNDER the hammer when you turn the nailer back over. Once you have done this part, simply slide the second piece in (the one with the fluted strip down the middle), slide it in fluted side up, then the 'T' piece (with the 'T' in first) then the last piece with the wider groove that contains the 'T' piece. Replace screws and you're back in business! This information may be in the instructions, but I have long ago thrown those away.
Oct 26, 2012 | Arrow ET200 Electric Brad Nail Gun
Resetting radio unlock code
I couldn't figure this same problem out so I ordered a factory replacement via EBAY for $20 and my son-in-law put it in while I was at work! Do you have a great son-in-law, too?
Jul 06, 2012 | 2002 Chrysler Concorde
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
My wireless controller on a vtech vsmile motion is not talking to the game. it has been a really long time since it has been played. new batteries are in. do I have to reprogram? couldn't find the...
take batteries out of console. Hold start button on console for 45 seconds. put batteries back in. press start to turn console on. controllers should work now
Jul 19, 2011 | Vtech VSmile VMotion Wireless Controller
So I picked up a 2006 mini last year and I noticed in the last couple of months that the overflow tank goes empty every couple of days. I hadn't noticed anything on the ground until I had my oil...
Start on a day you're not using the car. park it in a spot where any fluid leaks will be imeadiately obvious and if you see a fluid leak jack the vehicle on the spot and get under it and start looking for wet spots. It could be something as simple as a bad or loose hose clamp.
Jun 24, 2011 | 2006 Mini Cooper
Honeywell RTH230B 5-2 Day Programmable Thermostat Large Logo
101 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
