Dryers Logo
K
KENNETH PARKS Posted on Jan 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CONTROL LOCK GE GAS DRYER
EVERY TIME YOU PUSH START CONTROL LOCK LIGHTS FLASH AND WILL NOT START
jeff5may32
Level 3:
  • GE Master 1,258 Answers
  • Posted on Feb 02, 2015
jeff5may32
GE Master
Level 3:
Answers
1258
Questions
0
Helped
375113
Points
5289
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Ge gas dryer model dsxh47ggoww when I press start the start button lights up as well as the control lock but it doesn't start
This issue could be caused by a problem with the start switch or the control lock switch. I recommend checking to see if the start switch is stuck or if there is any debris blocking the control lock switch.
You can also try to reset the dryer by unplugging it from the wall outlet for a few minutes, and then plugging it back in.
If the problem persists, it would be best to contact GE or a professional for further assistance or repair.
Dec 23, 2022 • GE Dryers
How do you clear CL error on GE dryer
CL usually indicates that the Child Lock (control panel lock) has been enabled. This is useful when you clean the control panel. It also keeps someone from accidentally starting the dryer with a pet or another child in the dryer.
This is toggled on and off by pressing and holding two buttons. There is usually a line between the buttons with a padlock symbol in the middle or above that line. The phrase Control Lock or To Lock Control will be below the line. The symbol and text will be in a small font.
On some GE dryers, press and hold the Extended Tumble and - buttons for 3+ seconds. The CL indicator should flash while you unlock the control panel and then go off when you've held the buttons for sufficiently long. Note: if you hold the buttons for too long, you will re-enable the lock.
For the GE Profile DPGT650EHWW, press and hold Dry Level and Temp for the 3+ seconds. See page 6 of the Use and Care manual here: https://www.geappliances.com/appliance/GE-Profile-7-1-Cu-Ft-King-size-Capacity-High-Efficiency-Electric-Dryer-DPGT650EHWW .
I hope this helps. If you need help finding the control panel lock key, please add a comment with the model of your dryer.
Apr 01, 2022 • GE Dryers
I push start button and then I click saw. Why do lights flash a couple of times?
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
Plugged up dryer saw sparks...noticed the burn area near the grounding ... I could hear a click til around the 8th turn then tried it and it worked. ... My dryer doesn't initially turn on when I push thestart button, only when I put ...
How To Fix Dryer That Won't Start ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Will-Not-Start/
When the dryer won't start then troubleshoot common parts and problems like ... On alldryers, the door switch allows the dryer to start tumbling only when the door ... Gas and electric dryers have a motor that turns the blower and the dryer drum. ... and Stratton Parts · Echo Parts · Frigidaire Parts · GE Parts · Husqvarna Parts ...Missing: saw
WHAT DOES CONTROL LOCK ON A GE GAS DRYER MEAN
push the lock/unlock button for several seconds to unlock the control panel. on some it says lock on some it shows a key
Jan 31, 2015 • GE Dryers
My dryer only lights the first time.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Whirlpool Duet Gas Dryer won't start
Did you take the shipping blocks out? They are inside the machine. You will need to remove the access cover on the back and look in, you cant miss them. Good luck
Jul 26, 2009 • Dryers
Flash lights on locking doors with control
he is pushing the button a second time which is unnecessary.
it will cause damage to the lock actuators. yours will do it if you push the lock button a second time, but i do not recommend as stated above.
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
