Thank you for your inquiry, Steve Lesko!
I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
SOURCE: hi there, ive got an frigidaire washer atf6000es frnt load
yea board or latch)latch usually shows fault. the board is located left rear of unit, first ck for loose wire connection leading to it.
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: how to run diagnostic on frigidaire affinity ATF6000ES front load washer
Hello Tony bent - What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
