SOURCE: Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting
membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and please do not leave it running
unattended.
On this model, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame which comes with a new keypad.
In this case, you simply
move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you
have a shorted membrane keypad.
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at
our site, peel the old keypad off as in this
handy guide with pictures
, clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
our site, disconnect the keypad strip as shown
here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
