New needle, cleaned the bobbin case.
1. IS THE NEEDLE THE RIGHT SIZE FOR THE MATERIAL?
2. IS THE HOOP BIG ENOUGH FOR THE JOB? IF IT GOES OVER THE EDGE THE NEEDLES WILL BREAK.
3 IS IT SEWING AT ALL? ARE YOU HAVING PROBLEMS WITH GOOD STITCHES OR NONE AT ALL.? THIS WILL NEED YOUR REPAIRMAN TO TIME YOUR MACHINE.
4. FOR A TEST ON TIMING: REGULAR SEWING WITH STRAIGHT STITCH. 1. PLACE NEEDLE ALL THE WAY TO LEFT AND TRY SEWING. 2. PLACE NEEDLE ALL THE WAY TO RIGHT AND TRY SEWING.
WAS THERE ANY NOTICEABLE DIFFERENCE? IF THERE WAS THAT TELLS YOU TO GET IT TIMED.
