Was this problem answered? If yes, can somebody tell me how. My Casio LA670W is in 24hr format and I want it back on 12hr format. My watch have 3 buttons only. Mode, Start-Stop and Timer
you may find a manual from the manufacture. hold the mode button down 3-5 sec's. the hr should blink ,use the opposite side buttons to change the number, then press mode again mins blink change, do this and set hr,min,sec, am or pm? then date month,day yr. press final time and time should be shown with no blinking. you can also hold in all buttons and let beep 5 times it resets to zero defalt settings
kc 3982 Hold the top right button, then push once the bottom left button. That should do the trick.....I just got the same watch, Do you know how to change the time?
You need to press and hold both left hand buttons at the same time. This is the mode and the light. From this screen you have options to change to 12 hr or 24 hr clock, set day etc.. Hope this helps. I struggled for days before sussing it out. Hope this helps!!!
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once
more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes,
hours, month, date, day of the week. Simply press MODE when your
settings are complete.
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSINGRESET/LIGHT ONLY WHEN THE HOURS MARKER IS FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE WATCH IS SET TO 24-HOUR TIME.
