Tablets & eReaders Logo
A
Angie Hobbs Posted on Jan 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I retrieve my pictures back that I had taken with my tablet camera ? For some odd reason my tablet keeps erasing me pictures .
File manager the SD card
Jesse Allen
Level 3:
Master:
  • Master 307 Answers
  • Posted on Mar 16, 2018
Jesse Allen
Master
Level 3:
Master:
Answers
307
Questions
0
Helped
161095
Points
1872
Go to system settings and see if you are running out of storage space on your tablet.
If you own or have access to a Mac computer, you can try using Leawo Photo Recovery to recover your lost data from your tablet, it can recover photos directly from the internal storage of your tablet. Here's how to use it: hope it helps. Leawo Photo Recovery for Mac
Mithilesh Kumar
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 138 Answers
  • Posted on Jan 30, 2015
Mithilesh Kumar
Expert
Level 2:
Mentor:
Answers
138
Questions
5
Helped
56948
Points
563
You can have them back by Photo recovery process as your photos has been erased so the process would be this only. Also check your SD OR memory card may be storage space it not there for new addons. I suggest can suggest you services for picture recovery who can also guide you for the further precautions to be taken after retrieval. Digital Photo Recovery services to recover lost deleted or formatted...
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
2answers
I have a Mini IPad and my Icons got erased by accident how do I get them back
Go into your settings under general, there you should be able to reactivate the apps and icons that came with the tablet. If there are purchased apps go into App Store and retrieve them from the cloud
My son set a privacy password and now cant remember it. how do i get in to reset password?
There is no way to recover a lost password without erasing the device.
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
Go to the option for Factory Data Reset and select it. Scroll down to Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
1helpful
Matsunichi 97 tablet camera - how to change direction the camera faces. I warn to take pictures across the the room and not of myself.
Hi
I managed to find a manual for the M97 tablet which I assume is the one you are referring to here:
http://www.lepantab.com/Download/English_User%20Manual%20of%20M97.pdf
Having searched for "camera" on the pdf document obtained there is no mention at all of a camera on the back, just the camera on the screen side which obviously functions as a webcam for applications such as Skype. There was no picture of the back of the tablet, so I couldn't confirm that there was no camera there or means to swivel the camera. During my Google search I also found a YouTube video about this machine so I had a quick look at this here:
Matsunichi 9 7 tablet 8gb dual core M97
and part way through there were clear shots of the back of the tablet. There were no apertures through which a camera could "look" to take a picture, and this combined with the lack of mention of "changing the direction of the camera" I have to conclude that the camera is fixed and you have to point the screen side of the tablet at any scene you wish to photograph. Not very convenient !!
Hope this is helpful, if so would you please register that with Fixya
Cheers
Why is my ASUS transformer Pad saying to 'connect a camera' when I tap the camera icon or try to use skype?
If the tablet rooted or has a custom rom the correct camera drivers are not installed. Set it up with the stock rom and you should be good. Problem with custom roms is most of the time they were not set up for that specific model and some things are not going to work
How do I find my picasa pictures that was on my computer?
Usually picassa pictures are taken from the original place you stored them , Picassa does not modify their location
HAve you looked in your picture folder in my documents ?
My nexus 7 i cannot retrieve photos from my gallery ?
To fix this problem u can swipe left to go to the next picture or in the gallery. Another thing u could do is go to you setting den go to clear data. But to do that you have to have your pictures saved to your SD card (if u have one)
Error 110
I had a similar problem with my android tablet and this worked for me. Go to settings, manage applications, then google play store and then clear data. Then go back to manage applications and to google play services and then clear data. Once that is done then restart you tablet and the error should have been eliminated. If not you will have to do a factory reset which will erase all of your data on the tablet.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
