We have replaced our control panel PN 99003139, THREE times. Each time same thing happens. The lights and buttons gradually and intermittently go out. The dish washer will still run, so long as the start button is still working, but none of the lights work. So you just hope the cycle is the same as last time. This can't be a panel problem, but I am not sure how far down the line to look. We are ready for one last panel change and then we are looking for new dish washers.
Whirlpool parts come with a one year warranty WP owns Jenn Air take it back I have replaced this panel then had to go back and change again in 3 days it failed yes could be a bad batch of panels the panel is powered by the control is the control taking out the panel can't say it is a computer maybe sending to high a voltage to panel no way to test that
SOURCE: all lights are flashing but he dish washer wont
It might be that you had a power surge try unplugging the unit for a few minutes or trip the breaker.
good luck,
rsmith972278
SOURCE: The start button will not light up. Other lights
are you getting water into the machine? if not it will not start up. you may need the water inlet valve replaced.
SOURCE: soap not dispensing. Washer is running thru
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
atgg
SOURCE: same thing happened today
Replace the control panel yourself. Part is about 150. ten years with no probs for this DW must be a record....
SOURCE: The hidden control panel has only about half the
first retrieve the tech spec sheet behind the toe-kick panel located near the floor and run the diagnostics if it will let you do so w/o the full operation of the keys on the pad,then if it wont the touchpad or keyboard on the front that you use to select washing options has one or more shorted keys on this membrane pad and needs replacing,its available from appliancepartspros.com for $128.56 part # AP4365077
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
