Televison & Video Logo
Maya Burrage Posted on Jan 29, 2015
How do hook up a non HD TV to a blue Ray - Televison & Video
stephen Kiarie
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 32 Answers
  • Posted on Jan 29, 2015
stephen Kiarie
Contributor
Level 1:
Cheetah:
Night Owl:
Answers
32
Questions
Helped
6629
Points
62
Buy a converter box ..
We have a philips 42" HD TV. We havde a blue ray
theres extra speakers computer speakers you can hook up to port for louder sound.
1helpful
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
1helpful
Will the Playstation play blue ray disc on a regular tv or dpue the tv have to be HD
The PS3 will play blue ray discs on non HD TVs but unfortunately there will be no increase in quality when compared to a standard DVD.
If possible please rate this solution.
I just hooked up a sony blue ray to Samsung HD TV and it worked initially and now the tv does not get a signal from Blue ray model BDP-S360
Please unplug the Cable from the Blu-ray Player to the TV.
Then, press and hold the STOP button on the Blu-ray Player for more than 10 seconds.
Then, connect the cable from the Blu-ray Player to the TV and check whether it helps.
CAN A BLU RAY BE USED WITH A PROTRON PLTC-32C ?
Absolutly A blue ray is not really tv specific but if you want HD and feel the sound and video then sure a bigger better tv would do. But you can hook a blue ray up to any tv basically remeber the ps3? Same idea.
Yes it will work and then some!! Happy buying
please if this is Very Helpful leave some feeback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4helpful
How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Olevia 237t No Audio or Video on HD Channels
Try to connect the ROKU player to the television directly
Make sure that the internet connection to the player is from your router
Use your television remote to select the proper input to your television
Try this and check if it works.
It should work
1helpful
How to connect blue ray disc player to rca rear projection tv
Unfortunately, there are a couple potential problems. First of all, if you RCA rear projection tv is fairly old and is not a High Definition tv, you may not have an hdmi, dvi, or component connector cables inputs. Without these, you are left connecting your blu-ray only by the standard yellow (video), along with the audio (red and white) rca cables... either way, the High Definition portion of the blu-ray won't work with a non-High Definition tv. It may be time to buy an HD capable tv to use your blu-ray effectively...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
