CHECKED L.C.D
Good afternoon friend, thank you for the post!
I understand that you are stating the door open button is continuing to get stuck on your Frigidaire microwave. I would like to ask some additional questions to make sure I can provide additional assistance. First, which button are you referring to that is sticking? When I pulled up your model FGM0205KBB, I do not see a door open button. Could we verify the model number is correct? Once I have that information I look forward to assisting you. -Matt
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
