ERROR 23
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
SOURCE: How do you check for
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
