To fix, try this
Right-click on My Computer icon, and select Properties.
Click on the Advanced tab,
then select the Settings button within the Performance section.
In the Performance Options window, click on the Advanced tab, and then select the Change button in the Virtual Memory section.
Click the Custom size button...
Change the Initial size (MB) setting to 4000
Change the Maximum size (MB) setting to 4000
Select SET to accept the change, which will close the Virtual Memory window. Select OK to close the Performance Options window. And select OK to exit the System Properties window.
please rate my solution
have a nice day.
Follow the instruction below serially...
My Computer
> Properties
> Advanced
> Performance
> Settings
> Advanced
> Virtual Memory
> Change
> Select Any Drive
> Custom size
> type atleast 3000 in initial size & 3500 in maximize size in you have enough space in the drive you selected earlier......you can type more but no game or software need more than that
> Set
> OK ...... You may need to reboot your PC then
I hope this will solve your problem & speed up your PC.
