Wm3370ha owners manual
SOURCE: Washing Machine Capacity
ovenon what you what is 18lb to 20. Bosch is 18, LG 18 & 20 (depending on model), Whirlpool is 18 however I hear they have a 20 now as well. The big think to remember is that machines will break. Make sure you can get service in your area before buying. 2nd don't go by looks, but will it do the job I want to do, looks don't clean laundry. If LG is what you are really thinking of, call the local servicer and get his opion. If he works on lots of them, well there is the service history in a nut shell. Note, what propably took out your old machine is too much high sudsing detergent. Water will not affect the rear bearings, however detergent is designed to remove the bearings grease. Hope this helps.
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
