I reset my coby kyros mid8042-4 but when i tirned it on the original app selection was not there it will not download getjar so is basicly useless as i can get no apps
I btried to reset twice with same result the reason i was doing the rest is i tried to delete e books from ub reader it would delete them but when i tried to add new ebooks from sd card it would reload books i had deleted and that were NOT on the sd card i was worried about internal memory and confused so decided to start over i loved this unit until then
check the on off switch and the battery, if its something other than this it will have to go to a repair center . which more than likely will cost as much as a new tablet.
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
Take out the battery.
Reinsert the battery.
Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
Switch off the device.
Press and hold Volume Up + Home Button + Power Key.
After 2-3 seconds, release the Power Key.
You will enter boot screen, Select Wipe Data / Factory Reset.
Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Depends on the Android version you have on.
But commonly:
Settings (the pinion icon) > Wireless and networks > Wi-Fi setting (On). Then you select your wireless point and enter password.
Hope this helps.
Coby no longer uses GetJar, I would download 1mobile.com's - http://www.1mobile.com they have an app store that has an updated version of Amazon App Store.
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
