Try unplugging the set from its power source, let it sit for 10 minutes and then plug it in again, then turn it on. Are you getting any on-screen messages or logo display when you turn it on? Is there any backlighting showing? (in a dark room, the screen should have a faint glow). Try switching the input source using the remote. If the set is less than a year old, it is under warranty. If nothing is displayed ever on screen, the panel might need repair or replacement.
The green ligh goes on and off..no remote for it..and tv like 3 or 4 years old
If there is no remote, look for a control on the side bottom or back that says source. This presumes there are more plugs on the back of the set to plug things like DVD players into. Does the set glow faintly in a dark room when it is on?
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
