I am not sure you can add a pause in the Prefix per se, but you can increase the Intercharacter delay which should achieve the result you want.
Download the Product Reference Guide for the GM4100 from this page: Gryphon GD4100
Here is the direct link to the 13MB PDF:
http://www.datalogic.com/tools/download.aspx?iddwnfile=1608&path=%2fupload%2fmarketlit%2fmanuals%2fgryphon%2f820050514.pdf&name=820050514
You will need to print several pages so that you can scan the appropriate codes to change the scanner setup. Follow the instructions on the following pages:
Pages 47 and 292 describes the Intercharacter Delay.
Pages 351 and 352 in Appendix D give you the number scans you will also need.
You might start with a 10ms delay and increase this until it works. A little experimentation will surely solve your problem.
SOURCE: Using Y Cable, LS9208 Prefix appears along with I 2of 5 data (does not happen with USB cable)
hi
easy to remove the code. I can send emails with setting
Roberto
SOURCE: Need to program scanner to
contact Symbol/Motorola Help desk at 1-800-653-5350. You will probably have to use the scan 123 utility, but the LS2208 may not have the capability
SOURCE: Need to add prefix ~ and suffix / for ls2208. I
Have a read through this document.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
look at 13-4
have you tried scanneing the enter barcode after 6 ?
SOURCE: My 3800g barcode scanner puts
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to Click hear
Testimonial: "Works! Thanks so much. "
