Watches Logo
B
Brian Dickson Posted on Jan 28, 2015
Need a new safety pin strap for my ladies malice watch could you please help ?
Can't seem to find a dealer to advise me were to go
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Jan 27, 2008
SOURCE: Watch strap
Please call this number 1-718-7298600 x 272, order a strap for kc1232, usually it takes you 7 days to receive this strap, and there will be four new screws comes with your order, I believe it cost you $18.00 to have new strap.
Tsai
A
Anonymous
  • Posted on Mar 23, 2008
SOURCE: Timex 1440 Sport watch needs a new strap
Hi I have a 1440 sport watch , somehow I got it into 24 hr mode vs regular time. Can't seem to figure outhow to get it out of this.....HELP :)
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 31, 2009
SOURCE: DON'T KNOW HOW TO FIT NEW WATCH STRAP WITH PINS
Get pen knife and insert the blade between the watch strap and watch lug from the bottom side. Pry the springbar inwards using lever action. This must release the springbar.
Rate me, please.
Anonymous
  • Posted on Aug 31, 2009
SOURCE: How to adjust a Rubber strap
well all i did was cut the strap
Anonymous
  • Posted on Jan 26, 2010
SOURCE: I need a replacement strap for Fossil watch
I've been looking all over my area for an FS3041 strap too. Even the jewelry shop that has Fossils only carries crappy bands that won't do the watch face any justice. And fossil.com doesn't carry bands for past models, which this is. I may have to make one from an old shoe. :)
My DKYN is a ladies large D shape stainless steel case quartz. White leather strap. I have lost the tiny pin head that holds the strap pin in any suggestions please
sounds like a broken spring bar.They break all the time and can be replaced by any good jewellery store while you wait.
Aug 17, 2010 • Watches
I have been given a casio wave ceptor wvq 570 as a present. Unfortunately the plastic strap keeps detaching itself, by pulling the strap pin out. The strap seems undamaged but has a lot of play round the...
If the pin keeps coming out, then it seems likely that it is bent.
This can happen if the watch is fastened very tightly and your hand bends back until it strains the pin.
I suggest that you go to a jeweler and have a new one fitted.
1helpful
Ironman Triathlon Sleek Ladies Watch Band Rubber Strap Discolors
Unfortunately there is no way to get rid of that discolouring.This is due to sunrays+swetting+chemical composite of strap material. Would be too long to explain how it works, so, here is the link where you can order the new strap:
http://www.timex.com/gp/node/n/256542011/ref=sc_bb_c_11_251377011_15/190-2521384-6105829?ie=UTF8&node=256542011&no=251377011&timexBrand=core&me=A1S5XB33AHYRMX&clicked=center-1115
Rate me, please.
35helpful
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
1helpful
Help with removing links from a Calvin Klein ladies watch
There must be something wrong as ALL watch bands are held together by pins or screws. Did you try to unscrew them? These might be screws instead of pins. And if these are pins, they MUST come out because there is NO other way to shorten the band.
I would advise you to find the watchmaker, not the jeweller, and he/she will be able to sort things out.
P.S. Not all the bands has pointing arrows on them, so, no worries about that.
Jan 06, 2009 • Watches
2answers
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 • Watches
Top Christian Dior Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Christian Dior Watch Expert? Answer questions, earn points and help others
