A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: tv manual
Most likely this is a generic TV made either for the company you bought it from or a Manufacturer having it made for them. You can usually compare the TV to other brands and find one that is identical just made by someone else
SOURCE: need code to get sky
Hello 221 033 061 039 726 696
If your Tv is LOGIK; skay remote codes are :
If it is LOGIX; code is:
OK.
SOURCE: has anyone got a code
MY TV SWITCHES IT SELF OFF AND THIS PROBLEM ONCE BEFORE AS IT IS AN EX DISPLAY TV AND IT WAS ON A TIMER. SO I ALTERED THE SETTINGS TO OFF BUT FOR SOME REASON ITS GONE OFF AGAIN AND I CANT GET IT BACK ON.
SOURCE: logik 32inch tv comes on with blank screen saying reteving data once on cant use controller
Hello
the firmware of your TV has been currupted. It has to be reinstalled by internet. Proceedings ot upgrade the firmare can be had at its user manual. Go to that section and do the upgrade with correct firmware. OK.
221 033 061 039
726
696
OK.
