When I try to print from my MAC OS X 10.4.11 I get a Error 300. All connections are intact from computer and printer.
Kindly remove the printer from add or remove place
and then re install the printer from 0 it will start work and kindly remove the old printers from your computers which are no more available to you.
If you're facing Such Issue then don't worry have a look, your solution is here
Try out any of these solutions to fix Canon Printer Error Code b300:
§Turn off the printer, disconnect the power cord from the electrical outlet. Now, you should hold down the power button for a minute. Then, reconnect the power cord to the electrical outlet and switch on the printer
§You can also clean the ink cartridges contacts to fix this error code
§You should open the printer, wait for the carriage to slide over. Then remove the ink cartridges and clean the print head with cotton swabs dipped in hot water. Once it is finished, allow to dry the print head and replace the cartridges.
If you still stuck then do visit this site: Canon Support Code 300
Toll-Free No: +1-888-633-7151
SOURCE: refuses to print
Disconnect and switch off printer from pc's usb port. Go to add/remove programmes and uninstall printer software and drivers. Go to printer and faxes folder or go through control panel and ensure the pixma printer is deleted, if not right click and delete. Re-start pc and install drivers from your printers cd rom and re connect printer when prompted and not before (if no prompt when software finishes connect printer). Your pc should then idenitify your printer and auto install drivers. If the same error occurs, it's more than likely a hardware failure, and requires replacing.
SOURCE: "Error 1068 Could not start the Printer Spooler on local Computer"
Just to add to CoachTim's excellent solution, i find that removing the printer from the usb port as well as turning it off helps. But make sure you uninstall printer completely from add/remove programmes and check in the folder after that there is no canon printer listed. download this UK driver http://software.canon-europe.com/software/0024838.asp?model= Restart your pc before re installing and re connecting printer.
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
SOURCE: Pixma Mp630 dont sacnn and dont print Cd with Mac OS X 10.6
I can sympathise as a fellow MAc OSX user!
Make sure that you have all the installation files shown at the following link
http://software.canon-europe.com/products/0010643.asp
In Mac then start Solution Menu from the menu bar, select the Go menu, Applications, Canon Utilities, Solution Menu, then double-click Solution Menu. Select
Use Solution Menu to get the information on the machine or change the print settings by only clicking buttons on a screen. With Solution Menu, you can start the software applications supplied with the machine or display the operating instructions. It also provides you with the information on troubleshooting.
If you get problems then please come back to me for assistance with details of what you have done and what errors you get etc.
