Turned it off at mains then left it for a few minutes then turned on tv it went on standby an when I press channel button tv will not come on
SOURCE: turn off child lock
To unlock the Panel Lock,
Parent Lock, or Child Lock, follow these steps:
Note: If you don't have a remote, you may
be able to do the same thing by pressing the Menu button on the front or side
panel of your TV and using the volume or channel up and down buttons on the
TV to scroll to the Key Lock function and set it to Off.
SOURCE: GOODMANS GTVL26W26HDF - no Remote control/child lock is locked!!
hi just got a goodmans x pro witout the remote any chance you could let me no how to turn it on as its just on stand by now thanks
Instructions
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
