There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
