Removed bobin and case, still breaks needle
Make sure you are using the correct needle for your machine! Also check your manual to make sure you are inserting it properly. Some needles are rounded on one side and flat on the other. If you use the incorrect needle it will hit or insert it incorrectly it will also hit and break. June
Have you changed the needle? Is the foot down before you start sewing? Make sure the bobbin is inserted correctly. These are the most likely of problems. However if the needle is breaking or hitting some part of the lower mechanism then there may be a problem with the timing. However that is not TOO likely. Carefully try these items first and message me back.
These new electronic machines are supposed to be fussy -they kind of stop etc. if there is something not quite right. Just make sure all is ok before proceeding. Then try again. You can do it!
Moses
