On the twin cable where does the black plug in.have connected white & red ok . Vic
2.0Channel dual orientation speaker soundbar. Model aspect
    Sergeant:
  • 192 Answers
Usually ground or negative
Posted on Feb 24, 2016
3 Suggested Answers
SOURCE:
  • 40 Answers
SOURCE: 5.1 speakers connected to a dvd player ?
You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
------- If you don`t know how an RCA jack looks like,see this image
Posted on Dec 24, 2010
  • 57 Answers
SOURCE: I'm trying to hook up an Altec Lansing
You need to get one of these or something like it :
http://www.google.com/products/catalog?hl=en&biw=1024&bih=649&q=rca+to+mini+adapter&um=1&ie=UTF-8&tbm=shop&cid=15600543032554495997&sa=X&ei=2v89Tr_lCqjYiAL69aXDBg&ved=0CD4Q8wIwAw
it is a called a Mini/Rca Adaptor
Please Rate my Advise if it is helpful.
Posted on Aug 07, 2011
Onn soundbar will not work with Emerson flat screen tv. What am I doing wrong? hooked cables up red to red and white to white and plugged in power. Turned tv internal speakers to off. no sound
Some TVs produce no audio output with internal speakers turned off. A convenience for headphone users; an inconvenience for soundbar users.
Aug 03, 2018 | Emerson Televison & Video
I bought a wireless soundbar to hook up to my Smart flat screen tv, and the manual does not state anything on how to really do it...too simplistic and not enough info for one.
Find the Audio Out connections on your TV and run the dual RCA cable (Red/White) to the Input RCA jacks on the back of the sound bar unit. You may have to go into your Audio or Sound menu on the TV and turn off the TV's speakers in order for the Audio out on the RCA output to turn on.
Feb 23, 2016 | Ematic ESB212 Wireless SoundBar with...
Trying to connect samsung soundbar to Technika tv. Plugged aux cable (red and white) into tv then other end (black) into the soundbar. Still no sound.... Help ?
Hi probably a silly comment - have you connected to the AV in or Out sockets on the TV? Worth checking? also do you need to select an audio profile on your TV in order to divert from the internal speakers. Worth looking at your sound preferences on your TV
Jun 24, 2014 | Audio Players & Recorders
I need to wire my sony cd player into my fiat cinquencento but I have no idea how to wire it in I just spent 23 on a wire for the stereo an it only cost me a tenner for the actual stereo I dont want to...
most car stereos are simple to wire, especially sony!
Main power cable colours are:..
RED = LIVE (+)
BLACK = NEGATIVE (-)
YELLOW = MEMORY/SWITCH LIVE it will be next to the red and black cables
ORANGE AND WHITE = ELECTRIC ARIAL (IF FITTED)
BLUE = REMOTE WIRE (FOR AMP CONTROL IF USING)
You should now be left with a couple of audio out jacks and speaker cables,
the speaker cables are straightforward, most have a twin, ...E.G if you have a grey wire, this should be next to a grey and white (or grey and black, depends on model) wich is classed as its PAIR/TWIN.............
an so forth,...green, purple, white, brown.....ect ect
each colour havin a twin as stated ealier!! (they are twinned, as the solid colour is usually the negative speaker, and the solid colour with a stripe through it is usually the posative speaker connection (eg..single solid colour is (-)...and...solid colour with stripe is posetive (+)...)
Apr 30, 2011 | Car Audio & Video
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I have a pioneer 760 2 channel amp bridged to a kicker comp vr woofer. Amp has 8 gauge power and ground 18 gauge speaker wire run to woofer wooofer has 4 inputs two - two + . mine is run amp + to woofer +...
Ok, without knowing if you have the 2 or 4 Ohm Dual Voice Coil (DVC) version of the subwoofer, I'm going to assume you have the dual 4 Ohm version. The reason why is because, assuming you have the Pioneer GM-5300T amp, that amp does not support an 8 Ohm load. If you wire it in parallel, that would give you a 2 Ohm load. Parallel will be solid red connected to red/white dot, then to amp +, and solid black to black/white dot to amp -. Without knowing more specifics on the amp, that should fix the problem. Let me know what you get.
Apr 30, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
What does red versus black equal?
from cd player to amp:
connect red from cd to red on the receiver's CD input( and white to white) using RCA cables:
http://en.wikipedia.org/wiki/RCA_connector
Red is usually right channel and white left channel.
From amp to speaker, use speaker cable and and make sure that you connect red to red and black to black. Notice the stripe on the speaker wire to help you do this. you could think red as 'positive' and black as 'negative', though they are not in the theoretical sense, as they carry ac signals.
Aug 14, 2008 | Polk Audio RTi100 Main / Stereo Speaker
Altec Lansing VS 4221 Right Speaker crackle
First of all take a headphones and connect it to the TV and listen the sound.If it is OK the problem is or the cable or the amp.You probably have two RCA connectors on the cable red and white or black for input of the amp.Connect the cable to the tv again and change places of the RCAs (red to white on the amp and white to red).If cracling is now on the left speaker buy a new cable but if its still on the right you have problem with the amp.And you are right if everything is OK it shouldn't be cracling.I hope that this will help you
Apr 14, 2008 | Audio Players & Recorders
89 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
