Just checking on it but no idea on how to fix it
You have an in cluster factory engine tachometer (RPM)?
the tacho is meter in the cluster and does not use speedo parts or its cable.
its just a meter that needs power, ground and spark tacho signals
if all 3 are good, the meter is bad. period.
the tacho signal goes to the ignition coil minus lug, and will good, as engine runs. so... wires bad, to tacho or tacho bad.
ever price a new one? or even used? $100 used?
you willing to pay that much for just a factory tacho?
there is NO speedo cable. this old 93 is electronic, (rare on most 93 cars made, toy is advanced)
here is the proof, amazing how books dont lie....
there is a speed sensor.
the tacho and speedo use the same power and ground
leaving just one wire,r-g red-green RPM sig. pin 5 of cluster
an is SPARK primary sig. so if only tacho is dead.
then the tacho is bad, or that pin 5 wire is dead.
got you to just 2 possibles.
Remove the speedo cable from behind the cluster and from the gearbox. Its quick and easy. Replace it with a new one. If the problem is not fixed. Know you have a worn out cluster. Replace the whole cluster then.
Testimonial: "There's no speedometer cable on it, that's why im wondering if how am i going to fix it."
