Remove battery from phone tried delete tried to figure out menu in french
SOURCE: when I press menu/clock on
Since you declined to specify the model of your VTech phone, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download the manual to see how to change the language.
SOURCE: change lanauge to english not french on phone
Since you declined to specify the model of your VTech DECT 6.0 system, I can only direct you to enter it into the search box here and download a copy of the manual.
SOURCE: LS6475-3 phone #2 changed from English to French, how do I correct it??
Press MENU/SELECT when the handset is not in use.
Press up/down to highlight >Settings, then press
MENU/SELECT.
Press MENU/SELECT to select >LCD language.
Press up/down to highlight your choice and press MENU/SELECT.
SOURCE: language change cordless cs6114 need to change from french to english
Follow the instructions on page 8 of this manual.
Press MENU to see the menu.
Press VOL+ or VOL- to highlight
(Feature).
Press CH- to highlight Language.
Press VOL+ or VOL- to select
English
French or Espanol (Spanish).
Press M NU repeatedly to remove
the menu from the screen or the menu
will automatically disappear within a
few seconds if no buttons are pressed
on the remote control.
OK.
Hi pat stoddard, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model VTech DECT 6.0 phone?
