seethis causes and fix it. God bless you User Control and Display Board
If the washer won't start, the user control
and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be
defective. This part is often misdiagnosed, check other components
before replacing this time
Line Fuse
If the washer won't start the line fuse might have blown. Thermal Fuse
If the washer won't start the thermal fuse
may have blown. It can be tested for continuity. Watch our fuse testing
video for more information.
Line Fuse and Holder
have blown, or the line fuse holder might be damaged and need to be
replaced. Main Control Board
If the washer won't start the main control
board might be defective. This is not common. Check other parts and
causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if
there is power at the electrical outlet which the washer is plugged
into. Plug a lamp or radio into the outlet to check it. If the outlet is
dead, check the circuit breakers or fuses for the hom
Power Cord
If the washer won't start, check to be sure
there is power to the electrical outlet for the home. If that is OK, the
power cord itself might be defective. This is rare. You can check the
power cord with an Ohm meter for continuity.
Its hard to tell exactly what causing it to squeal during the mixing of water and stop in the middle of the cycle full of water, especially when the make and the exact model number is not indicated.. But a loose connection or electronic glitch is evident as manifested by the unplugging of the washer. This problem is common to Maytag Neptune Front-Load Washers.
Indicate the exact model number of the machine for further and more
specific troubleshooting and repair advice. You don't
have to accept
or reject and rate this post to add
information
or post comments and follow-up questions.
Check the belt. If it is good,
Bail out the water.Open the front panel. Remove the hoses to the drain pump. Clean the debris from the pump. No debris, replace the pump.
I was about to order a new lid switch assembly, but I decided to try one more thing. I disconnected the wires from the check switch and cleaned the connections - there was a layer of oxidation. The machine started right up after I reconnected the wires and plugged it back in.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
